londo
#1 Posted : Wednesday, January 8, 2014 12:30:36 PM(UTC)
londo
Need to replace ignition module and all 4 igniters. How do I access these ? Also need the part numbers if available.
VikTech
#2 Posted : Thursday, February 6, 2014 7:45:06 PM(UTC)
VikTech
Module is on rear right of unit. remove island trim or back guard and module is accessible from there. Ignitors are built in to the burner base. filter strap wrench like used with oil filters on cars will get the venturi that holds down the burner base off. there's also a tool out there RH-SBW that is easier to use but costs a bit more to remove these.
