John bluetex
#1 Posted : Wednesday, January 8, 2014 9:09:34 AM(UTC)
John bluetex
After replacing the spark module with W10331686, after a stove top spill caused it to fail, the bake and broil ovens will not stay lit. They will ignite for approximately 15-20 seconds then turn off. Is this a likely igniter issue for both Broiler and Bake ovens? Or is some other part failing or has failed. The new spark module does have an LED troubleshooting sequence, but the stove has to be disassembled to read it.
NOTE: The original failure caused the spark module to fail at sparking for the stove top burners as well as the oven.
Wise council is needed and appreciated.
johnsonam1
#2 Posted : Wednesday, February 3, 2016 8:25:03 PM(UTC)
johnsonam1
John,
I have the identical issue with my oven after replacing the spark module. How did you end up resolving this issue oven/broiler not staying lit?
Thanks!
Raegangibb
#3 Posted : Monday, February 6, 2017 8:54:25 PM(UTC)
Raegangibb
Hi guys, I have the same symptom with the burners not staying lit for more than 5-10 seconds but did not replace my spark controller. What did you end up having to do to fix this?
