bcnelson65
#1 Posted : Tuesday, January 7, 2014 4:14:31 PM(UTC)
bcnelson65
I am replacing the bake element. Have the right part - removed the old one by removing the two screws. When I pulled it out the electrical connections on the element were only connected to one side - the other wire must have fallen off on the other side of the hole that it goes through. Anyone have any clue how to get to that wire?
#2 Posted : Wednesday, January 8, 2014 2:17:18 AM(UTC)
Be sure that the power is off.
Many units still have 120 volts to one side of the element even when the element is turned off.
You could get a fairly stiff piece of wire (coat hanger etc.), make a small hook at one end and go fishing.
if you cannot get it then you will have to pull the oven.
bcnelson65
#3 Posted : Wednesday, January 8, 2014 4:36:13 AM(UTC)
bcnelson65
thanks for the info - and the tip on the power (that might have been too exciting). I was almost thinking that something magnetized might help - hoping I can get it as I suspect pulling a double oven out isn't much fun
VikTech
#4 Posted : Thursday, February 6, 2014 7:46:52 PM(UTC)
VikTech
Groups ready for retrieval: Registered
maybe a bit late, but yes, you'll need to pull the unit and access it from the rear wall. there was a 50/50 shot that the wiring would be just barely long enough, or no chance that it was ever coming out with the element.
