Compressor occasionally won't start. It cools fine once running. Is the start relay, run capacitor, and or the temperature control thermostat the most likely culprit? Thank you.
When it fails, do you hear a clicking noise from the compressor. If not, pull the back off and feal the compressor, is it warm and vibrating, or cold and not vibrating.
There is no clicking. Will pull back off and check compressor heat. Wife reminds me that temp sometimes fluctuates from around 32 - 40 generally overnight based on the refrigerator alarm readings (so during that period of time no one is opening the refrigerator). Thank you for your help.
