AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer keeps blowing thermal fuse even after everything is cleared of any blockage
My dryer keeps blowing the thermal fuse. When I purchased the second one I pulled the vent tube inside the dryer to make sure there was no blockage inside and then I unplugged the vent hose from the outside vent and ran it with a pantyhose attached. It ran for approximately 50 mins and then blew the fuse again. I really don't know where to go from here. I can't afford to keep buying fuses till I get it right. I also refuse to just let anyone work on something that I can do for myself. :confused:
I am having the same issue, and am at a loss:-(
Dryer Repair
