mcki272
#1 Posted : Friday, October 16, 2009 8:26:47 AM(UTC)
mcki272
My Maytag Gemini Double Oven with stove has both the Stove Top and Both Ovens that will not come on. Electric is still on as the Clock and other items work (Timer etc.) None of the heating elements will come on. What parts do I need? Thank you.:confused:
#2 Posted : Friday, October 16, 2009 9:49:17 AM(UTC)
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010107.pdf
Sounds like you have lost the 240 volts.
Have you tried turning the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Next check at the plug to see if you have 240 volts.
Then at the terminal strip in the unit. Also check here for a wire that may have burned off.
