Protofactor
#1 Posted : Sunday, December 22, 2013 8:59:58 AM(UTC)
Protofactor
When start button is pressed, there is a click/buzz and the machine goes black. The readout then flashes PF twice. When I check the diagnostic mode, it shows 8:88 and no error codes. If I hit the Cycle Signal button it goes black just like when the start button is pressed.
I recently went through all the steps on the Service Technicians manual and determined the Machine Control Board was bad. I replaced the Machine Control Board and it worked for the past month until it started doing the same thing-- going black when the Start button is pressed.
I'm definitely an amateur at this and could use some suggestions. These Machine Control Boards are not cheap! Thanks in advance.
Protofactor
#2 Posted : Saturday, December 28, 2013 7:51:32 AM(UTC)
Protofactor
OK, how about rephrasing the problem... What would cause the Electronic Control Board to go bad? Is there another part I should check that is overloading the Board? Is there another part that would mislead the diagnosis and indicate the Board, when it's not the Board that's bad?
