OK, I bought the LED transmitter from you. The same thing happens as before. I have to return the part. Please explain why the red LED won't stay on for more than 10 min? Do I need to buy an ice maker from you also? I already replaced the control panel. :mad:
Seems like a power problem to the board on the right, should have power to the black and white wires. If the light goes out when you close the flapper and door switch, it's switching to infrared mode, invisible, camera would confirm.
