Blake Powell
#1 Posted : Thursday, October 15, 2009 8:30:34 PM(UTC)
Blake Powell
I have removed the fan cover and the two screws that hold the heat element in the lower oven but the element does not come loose from the wall. What else do I need to do?
Once it is removed, can I check the element with an ohm meter?
Thanks,
Blake
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
lower oven heating element does not get hot (Oven Repair (including Ranges and Cooktops))
by rbotthof 11/19/2009 7:46:01 PM(UTC)
Lower oven heating element (Oven Repair (including Ranges and Cooktops))
by Joeknight 12/20/2007 10:28:09 AM(UTC)
