larry j k
#1 Posted : Friday, December 20, 2013 3:03:19 PM(UTC)
larry j k
I took the ice bin out to clean and now it won't go back in. It appears that the screw in the coupler is keeping the bin from going down far enough to seat. Either that or the motor shaft is too high, My problem is that it came out of the freezer a little hard but it was in place and has worked fine for at least a year this way..It appears to be about 1/8 of an inch from seating.
Any help wanted and appreciated....
larry j k
#2 Posted : Saturday, December 21, 2013 3:47:37 AM(UTC)
larry j k
This is Larryj k .....is it possible that the motor shaft pulled up when the bin was taken out? It did come out hard. Other then that I can't figure it out. If that were the case what would I do?
Water freezing in Ice maker bin (Refrigerator & Freezer Repair)
by studabaker4141 12/3/2010 5:48:46 AM(UTC)
