fan motor buzzes wont turn either way when on when I give push start This is a downward draft motor
Someone please help me and tell me how to remove
Here are your parts Parts for Jenn-Air C301 Cooktop - AppliancePartsPros.comI cannot find any tech data on this unit. I am assuming that the motor is 120 volts. It may say on the motor housing. If it does measure across the motor windings to see if it is getting 120 volts. If yes then the motor is shot. |
THIS FORUM IS DEAD!!!!!!! |
