Hello!
Whrilpool Side by side Model ED5RHEXNL03: Frost in freezer @ ice chute for ice dispenser. Dispenser cover doesn't close completely. Found what I think is called (per parts illustration) the Mechanism Delay on the end of Mechanism Door Assy. white plastic rod. The Delay did not seem to be doing anything just hanging from the end of the rod. Is this the problem and if so, where does the Mechanism Delay go? The parts illustration doesn't show where the Mechanism Delay goes.
Thanks, MakMak
