I have a Maytag gas range Model number MGR4452BDW and serial number 14436286JL. The burners work fine, and the oven will heat up, BUT won't heat up to anywhere near the temperature set on. Was turned on 5:30 am and by 9:00 am it was only up to 350. Any help would be appreciated.:confused:
Originally Posted by: buddyrhonda  I have a Maytag gas range Model number MGR4452BDW and serial number 14436286JL. The burners work fine, and the oven will heat up, BUT won't heat up to anywhere near the temperature set on. Was turned on 5:30 am and by 9:00 am it was only up to 350. Any help would be appreciated.
