ken4
#1 Posted : Wednesday, October 14, 2009 6:16:35 PM(UTC)
ken4
How do I remove the inner basket after I have everything above and including the spanner nut removed ? I try to lift it out put it doesn't budge. Do I have to use some type of puller? The washer is leaking water from above the gear box and I want to replace seals and gaskets.
