fordtool
#1 Posted : Tuesday, December 10, 2013 5:42:41 AM(UTC)
fordtool
This dryer will just keep running in an automatic cycle after running 2 or more loads. If moved to the timed cycle it will advance normally.
I suspec problem may be the moisture sensor but am not sure how to test. Any suggestions?
#2 Posted : Wednesday, December 11, 2013 2:43:24 AM(UTC)
Parts for Kenmore Dryer 11067072600 - AppliancePartsPros.com
It has info on the moisture sensor.
I would try cleaning between the moisture sensor strips with isopropyl alcohol.
Just be sure to let all the vapors dissipate before trying the unit.
File Attachment(s):
67072600.pdf (413kb) downloaded 8 time(s).
