BioBob
#1 Posted : Saturday, December 7, 2013 12:38:56 PM(UTC)
BioBob
I have a Whirlpool KGST307HBS4.
Recently when heating the oven there is a strong gas odor that fills our kitchen and is very noticeable. From my research I believe its caused by a bad ignitor. Should I replace it with the part listed below?
Whirlpool 9753108 Ignitor, Oven & Broiler Burners - AppliancePartsPros.com
Thank you for your advice.
Mark
BioBob
#2 Posted : Tuesday, December 10, 2013 5:24:30 PM(UTC)
BioBob
bump!
Anybody?
BioBob
#3 Posted : Monday, December 30, 2013 2:55:32 PM(UTC)
BioBob
The oven is now failing to heat up, whether its the bottom heater, or the broiler. Both top and bottom elements glow red, so I know they are working, but the oven is not heating.
Would this be a problem with the temperature sensor? Is there some type of thermostat that opens the gas valve?
Mark
