trisitan
#1 Posted : Saturday, February 9, 2008 12:02:51 AM(UTC)
trisitan
Before I go ahead and order the cross flow blower kit (AP2834045) for my Thermador double oven, how hard is it to install. Does the oven need to be removed from the wall and the part replaced from the back?
Thanks,
Tony
#2 Posted : Saturday, February 9, 2008 3:39:10 PM(UTC)
Hi Tony,
As you can see from the break down diagram this part (#3) is located on the back of the oven and the unit has to be removed from the cabinet to access the part.
The hardest part of the job is to remove the oven from the cabinet due to heavy weight.
