Unit is just over 1yr Samsung left me hanging, if I unplug the unit for ten min it seems to reset and then I can run it but it intermittently quits, running a spin cycle to get the water out of the dirty clothes that were stranded. I have electronics background so any tech help would be great.
One other note problem started with not beating able to start a wash cycle, would press start it will beep but won't start, walk away for a few minutes and keep trying until it starts.
Can someone step up and try to help me, I need to get this fixed and no one has replied to assist. Thanks
Great forum absolutely useless if no one wants to help what a waste of time.:mad:
Well that's because anyone has no idea what the problem is..maybe you wanna show us the trouble via pictures..if possible. Xtreme Nitro
I was able to get the clothes out several days ago. The cycle will not start when the start/pause button is depressed. The it may or may not run a complete wash cycle. If it stops during the cycle the key icon in the upper left will be lit as well. 4wheeler attached the following image(s):
Hello there, one of my technicians is facing this exact issue that you experienced. I know this is a bit old now, but were you able to find a solution to fix this? Currently I am thinking of replacing the control board. Help is greatly appreciated on this one. Thanks in advance.
