Hi, I need to replace the Oven Latch Asm on my GE Oven. The part has failed after running a clean cycle. Display flashes LOCK and no other functions will work. I was wondering if the part can be replaced/accessed without pulling the unit out from the wall? Any help would be appreciated!!!:) Thanks Anne
