Electronic ice maker problem. The tube that feeds water into the tray freezes solid. Thawed the tube and made three batches than frozen again. The tube seemed too long and right up against the unit, thinking this was keeping water from draining I trimed it back. Again three batches and frozen solid.
Replace the water inlet valve. What is happing is that the water valve is leaking like a dripping faucet but instead of dripping out the tube if freezes. Hope this helps! Refrigerator repair guide
Originally Posted by: KROGERS  Electronic ice maker problem. The tube that feeds water into the tray freezes solid. Thawed the tube and made three batches than frozen again. The tube seemed too long and right up against the unit, thinking this was keeping water from draining I trimed it back. Again three batches and frozen solid. maybe you need to level the unit
