kevinsbby1
#1 Posted : Tuesday, December 3, 2013 11:15:28 AM(UTC)
kevinsbby1
hello I have an amana side by side it stopped running I contacted you and then ordered part, (evaporator motor) installed it. it worked perfect for 2 days then stopped cooling. I can cut it off for awhile plug it back up it will run a day or two the stops cooling again. I noticed that 2 of the lines on the back frost up, this is when the evaporator motor stops running, and stops cooling. :(
can it be repaired or is it done for?
