sabino pesarillo
#1 Posted : Saturday, November 30, 2013 2:55:41 PM(UTC)
sabino pesarillo
my washer pauses during the wash cycle. slo-fill i guessed. so i tested the inlet valves. on the valve that has a single inlet with two outlets, one ejected the water forcefully while the other outlet when energized let the water out in a weak stream. Is this designed this way or should they both eject the water with the same force?
