hi The basket inside the washer doesn't center itself when empty. Should it? When spinning ,machine dances around , have to sit on it . A level says it's level. Have put plywood under rear legs as the self levelers aren't functioning. Also have a plastic washer tray under it on a ceramic floor. Thank you for being there.
