This unit is cooling fine. My problem is when the unit is running and we open the door, the interior light dims and flashes. The digital control on the door then flashes red for door open and warm temp. The light stays in the interior when the unit is not running.
I am letting it reboot by unplugging the unit and have cleaned under it several times. Once more may not hurt. Any other ideas?
Mine is doing the same thing. It ended up continuing to flash even after the door was shut. Were you able to figure out what was wrong with yours?
