TommyK
#1 Posted : Tuesday, October 13, 2009 1:31:57 PM(UTC)
TommyK
Several weeks ago, I knew I needed a new socket for the large front burner. Actually, I need a couple. Then this past week the large front burner popped and you can see a hair line fracture in the coil and it no longer heats up. I assume it has fused.
While I've found the burner using AppliancePartsPros site, I have not found the socket it plugs into. I've looked at all the drawings, but to no avail. Can someone help?
#2 Posted : Tuesday, October 13, 2009 3:33:38 PM(UTC)
The model number you posted is incomplete - the last digit is missing. The receptacle is shown as #9 on the cooktop diagram and Replacement parts for WHIRLPOOL RF302BXEN1 | AppliancePartsPros.com
- The receptacle Part number: AP3030713
TommyK
#3 Posted : Saturday, October 17, 2009 4:56:18 AM(UTC)
TommyK
Looks like the critter. Thanks Gene.
Some assembly required, eh?
The last time I replaced a socket it came with ceramic wire nuts. This one appears to have... heat shrink insulation?
#4 Posted : Saturday, October 17, 2009 4:40:59 PM(UTC)
You are welcome. The wire nuts should be included as well together with the instructions.
