lost power during night now oven has in display e1-f1 what is necessary to correct problem
Your model number seems to be missing the last digit. I am assuming it is a zero as that is what comes up when I search AppliancePartsPros. See the attachment for the tech sheet. If the code will not clear then a check sum error is usually a blown control board. |
THIS FORUM IS DEAD!!!!!!! |
