Whirlpool side by side fridge won't stay running
Need a model number. Find your model number - AppliancePartsPros.comAlso more info on what you mean by "won't stay running". Exactly what is running and what is not, time between failures, what you do to get it running again, any noises/symptoms etc. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Need a model number. Find your model number - AppliancePartsPros.comAlso more info on what you mean by "won't stay running". Exactly what is running and what is not, time between failures, what you do to get it running again, any noises/symptoms etc. Model# ED25PQXFW02 When it runs everything runs, fridge & freezer section even icemaker and dispencer in front door. They all run anywhere from 13 hrs to full day then all of a sudden it is shut off again. To get it running again I turn control knob off then back on again and fridge starts running again you can hear fan and everything start up and run again just dont know for how long?
