lhenman
#1 Posted : Monday, November 25, 2013 6:32:50 PM(UTC)
lhenman
I'm guessing this unit is over 10 yrs-it was left in the house 6 yrs ago. I ran the dryer Saturday 4 cycles in a row. Each time cold wet clothes- the drum is turning etc. No heat. The ignitor glows when turned on. I fiddled with it turning it on and off several times and it will light eventually and it will run the cycle with heat i found after playing with it. For three days I have done this trick until I hear the gas ignite- but obviously there is something going wrong. The.best I can tell.it would be the gas valve coils but needless to say I have never worked on a dryer before. I got the replacement part but being non returnable after opening I was hesitant to replace because three repair shops thought it was odd I could get it to light after trying it a few times. Before I waste a 50.00 part I thought I would ask for suggestions. I read this part can gradually go bad so is that possible that its hit or miss until it finally blows completely or is it something else?
gas dryer not lighting properly/ every time (Dryer Repair)
by lhenman 11/25/2013 6:51:41 PM(UTC)
