I have a whirlpool gas dryer- model no. LGR8648LW0. The lint screen is on top. Dryer is working but will not heat. Replaced the coils- still not heating. Seems like it might be the thermal fuse. How do I get to the thermal fuse on this model? Remove panel on back? or remove front panel, then remove drum? Any help would be greatly appreciated
Take off the back and it is located on the lint shute that come down the cycling thermostat is right next to it. It's held on by one screw.:o
