How Hard Is It To Install An Upper Oven Control Relay On A Double Wall Oven??
If you mean a control relay on the control board/assembly, it is usually not that hard if you have some soldering experience.
You will need a soldering gun, rosin core solder and a solder sucker or solder wick.
You also have to be able to get at the solder side of the board. |
THIS FORUM IS DEAD!!!!!!! |
