leigh314
#1 Posted : Sunday, November 24, 2013 2:51:28 PM(UTC)
leigh314
The top burners on my gas stove work fine. The oven stopped working months ago (summer) Now, it is getting winter, and I would like to use it.. so, Hubby replaced the glow igniter (burnt) and still not working,, No glow, no gas, no heat.. no power to the oven igniter.. NOW WHAT???
Appliance Ninja
#2 Posted : Sunday, November 24, 2013 3:48:05 PM(UTC)
Appliance Ninja
If you have a meter, you can test for 120 VAC at the igniter. Test from each wire to ground when the control is turned to a baking cycle. If you get no voltage, the oven control is faulty. If you find that to be the case, the oven control is available below.
Whirlpool W10312659 Cntrl-Elec - AppliancePartsPros.com
If you do read voltage but the igniter still won't glow, the gas valve is likely faulty. The neutral line to the igniter comes from that valve, that is why I want you to measure to ground when you test for voltage. If you find voltage from the igniter wires to ground, the valve is available below.
Whirlpool 98014893 Gas Safety Valve - AppliancePartsPros.com
Of course, loose wires or connectors can cause this issue as well, so be sure to look at the wiring and assure all connections are secure.
