Oven is not heading up to what the Temp should be. Example, set Temp at 450 and it will be 425. This happens with other Temp setting always being lower. I cannot find how to Calibrate the oven to the right Temp. Any help would be appreciated. Thank you.
Page 10 in the Owner's Manual gives specific calibration instructions. The manual is available at the link below. CLICK HERE
Thank you. Did as the manual said. Set temp to 400 and was just about dead on at 400. You are so fast in a response. Have a great Holiday coming up.
Very well done, nice work! Thank you, Happy Thanksgiving!
