My machine washes all the through, when it gets to the rinse cycle it goes half way and then stops. It displays a code of nF. i have checked the screen to make sure the water flow is not restricted and checked the water pressure. Any one seen this before?
Since it stops at the fill cycle, the cold valve is likely having issues. You will likely need to replace the valve, but you can test it for voltage when it is supposed to be filling. Do you hear it humming or buzzing when it should be filling?
makes no noice how do I check with volt meter
You will need to remove the top panel to access the valve and test between the two wires for 120 VAC at the beginning of the rinse cycle when the cold valve should be filling.
I will test tomorrow and let you know what i find out. Have a good night thanks for the help
