As I was loading my dishwasher this eve, my 80 lb dog stepped on the door while in the down position. It now extends slightly past 90 degrees and has a slight "click" when putting in up position. Do I need to change the hinges? Is there a stop I can adjust?
The hinges will indeed need to be replaced. May I please have the rest of your model number so I am able to provide you with accurate, model specific information?
From the side of the door... SHU5305UC/UC12 I'm pretty handy and mechanical...is there a manual to see it? Thanks for your help.
