This is the scenario. The stove burners work fine. The oven bake is not working due to an expensive control part and needs the igniter as well. The oven broiler will work fine on low temperature or high temperature setting. So now the oven is limited to just the broiler flame up top. I'm not sure how to be able to get the parts being off work injury and to get the oven bake working for Thanksgiving turkey. Stupid question. would the broiler flame be able to cook the turkey in this emergency if the turkey was put way down on a lower oven rack. Thank you. Maybe someone has a idea.
The turkey would burn on the top and the oven would likely overheat and not maintain any type of reliable temperature. Are you sure the control is faulty? Do you have a meter to test voltage with?
