the dryer says 2 minnuts on thedry time 60 seconds in screen reads1 second then it stops and wrinkle block light is on
The time remaining displayed is an approximate time, unless in a Timed Dry cycle. The time will change according to the resistance of the clothing detected by the sensors. Can you double check your model number, please?
