Bought and received item # 36 for compressor on and off in 9 sec or less but can't find a place to install . Thanks This is usually a piece of cake fix but dunno about this location.:confused: :confused:
That relay is on the LH side of the compressor (facing from the back) in the back of the machine, under the plastic cover. It pushes onto the pins that are part of the compressor.
Make sure you make a diagram of the wiring before you replace it. These ptc 'devices don't fail often, if you measure 5 -8 ohms across the input spade terminals of the old one, it's good.
