ddazzle007
#1 Posted : Sunday, November 10, 2013 8:13:38 PM(UTC)
ddazzle007
how do i check to see if my compressor is good on this model ...it is a 230 / 3 phase that uses an inverter board ... im trying to figure out if the compressor is bad or if the invertor board is bad
#2 Posted : Monday, November 11, 2013 1:32:45 AM(UTC)
What is the problem, no run, noise??
ddazzle007
#3 Posted : Tuesday, November 12, 2013 7:09:07 AM(UTC)
ddazzle007
the compressor doesnt kick on
everything else in the fride appears to work
Appliance Ninja
#4 Posted : Tuesday, November 12, 2013 7:23:10 PM(UTC)
Appliance Ninja
The start and run windings should both measure about 6.4 ohms of resistance. The service manual for your refrigerator is below, page 5-3 begins instructions on testing the inverter and compressor.
GC5SH Manual
#5 Posted : Wednesday, November 13, 2013 1:53:07 PM(UTC)
Best to verify each compressor winding is not shorted, or shorted to ground.
If ok, you probably have a bad inverter, but it is best to monitor the input current to protect the new inverter if the compressor draws excessive current.
