VTX Rider
#1 Posted : Monday, October 12, 2009 3:43:44 PM(UTC)
VTX Rider
The dryer will heat but not at full temperture. The loads have to be run twice. The original problem was it started out warm but stopped. I cleaned out the vents. I pulled out the lent catch and clean below. It started to heat better but it seems it still does'nt get hot enough. I'm able to use a meter but not sure what part to check. Also to get to the assembly, do I have to pull the whole shell off. The model is a MAGIC CHEF CYG2000AWW Dryer - Gas
VTX Rider
#2 Posted : Wednesday, October 14, 2009 4:54:14 PM(UTC)
VTX Rider
Any clues on this? I don't mind and can swap out parts but would rather replace the part that's broke rather then do it all.
