dill36@aol.com
#1 Posted : Thursday, November 7, 2013 1:52:43 AM(UTC)
dill36@aol.com
The refrigerator stopped running last night and the lights are also off in both compartments. I checked the circut breaker, switched it off and on again, and it seems ok. Is there some easy check that I can perform...a fuse or something?
#2 Posted : Friday, November 8, 2013 12:47:04 AM(UTC)
Parts for Whirlpool KSSS42QHX00 Refrigerator - AppliancePartsPros.com
The wiring diagram does not show a fuse/breaker that will kill power to the entire unit.
First check that there is power at the wall receptacle.
If OK then check for power on the input and output sides of the power switch.
File Attachment(s):
KSSS42Q.pdf (1,537kb) downloaded 20 time(s).
