butterbuns
#1 Posted : Tuesday, November 5, 2013 4:03:04 PM(UTC)
butterbuns
Dishes Don't dry. They are cold and wet when cycle is done.
#2 Posted : Wednesday, November 6, 2013 1:17:59 AM(UTC)
I cannot find any info on the given model number.
Tried here and the Frigidaire site.
Please check it.
Find your model number - AppliancePartsPros.com
If this is not a North American unit then info is probably not available to me.
Unplug the unit and check the heater resistance.
Not sure what it should be but should be less than 500 ohms.
Also be sure to disconnect one side of it when measuring.
This ensures that you do not rad an alternate/parallel circuit path.
Follow the wires to the heater. many units have a high limit thermostat in the heater circuit that may be open. Should be 0 ohms at room temperature.
