This has been going on for many years, but lately with every use….. Our Jenn Air W30400 will frequently shut itself off. Usually on warm up- but also after it reaches temp. It will usually hold the food hostage, lock the door and be unable to reset anything on the keypads. Until after a short period it will decide to release everything….. I have replaced a few of the buggy electronic parts on this oven in the past….While it is not a young oven- it doesn't have that many miles on it…. Any advise??? THANKS….
The other electronics I replaced were the capacitors in the control panel circuit board when the display went dim several years ago…. I am thinking my problem is either the Relay Board or the Control Board? Since both are pricey parts, can anyone direct me in a certain direction… Or advise me on a diagnosis direction….. Any thoughts would be appreciated…. Thanks….
The problem still exists….. I have replaced many parts to no avail….. 1- replaced temp sensor 2- replaced Relay Board 3- replaced control board
We still have the issues--- What could it be???
