This is a gas dryer and the estimated time it gives for any of our typical loads in sensor dry mode has gone up by about 50% in the last week over what it used to indicate. The actual drying time seems to be what it used to be, though.
Any troubleshooting suggestions will be greatly appreciated.
P.S.: Since the original post, I've cleaned the sensor bars with alcohol but that did not fix the problem.
Try the timed dry cycle instead of moisture sensing cycles it should dry most clothes between 45-60 minutes. Check your washer clothes coming out also and see if your washer is spinning out the clothes good enough alot of times washers are the culprits not spinning out the clothes good. Come back with your results on timed dry.
