princesswarriorblade
#1 Posted : Saturday, November 2, 2013 5:56:09 PM(UTC)
Im attempting to help a friend fix his washer. I had helped him once before and I remember I found a few simple steps pushing different buttons and I was able to get his washer working again however that was several years ago and I don't recall the exact problem nor the solution ... regardless that's why he has asked me to fix it again.
The issue is the washer will not start... the only button that does anything is the end of cycle/control lock button. if I hold for 3 seconds the light will illuminate indicating that it is in the locked mode and I can do the same and the light indicator will turn off. There is no response from any other of the controls, while locked or unlocked, and Ive attempted pushing several combinations with no luck. however while it's in the locked mode I can still open the door to the unit. I would think the door would lock in the locked mode. does that mean that the door latch is not engaging?
sidfink43
#2 Posted : Sunday, November 3, 2013 3:49:14 PM(UTC)
sidfink43
Underneath the top should be the tech notes that will tell you how to generate error codes and do some testing.
Of course if the problem is the main control, then it cannot diagnose itself most of the time and you will have to replace it on spec.
If you decide to do that and get the part from this site you can return it if that is not the problem.
Good luck, hope this helps.
scottthefixitguy
#3 Posted : Saturday, December 17, 2016 10:33:01 PM(UTC)
scottthefixitguy
If your duet washer won't start its most likely due to a bad part behind the start button.
Here's how to fix it at home for 35 cents: https://youtu.be/N8rz8sclwAg
Whirlpool Duet Washer Wont Start (Oven Repair (including Ranges and Cooktops))
by PCARAMELJACK 8/7/2015 10:12:21 AM(UTC)
