Ish1105
#1 Posted : Friday, November 1, 2013 2:53:41 PM(UTC)
Ish1105
My dryer will not heat still and i just replaced high limit thermo,thermal fuse,control thermo and the heating element. The dryer runs but it just will not heat up.
#2 Posted : Friday, November 1, 2013 11:45:09 PM(UTC)
Here are your parts, includes a wiring diagram.
Parts for Admiral ADE7000AYW Dryer - AppliancePartsPros.com
Note that the right part of the wiring diagram is missing.
The Motor Cent Switch 4 goes to L2 Power.
Have you checked the power to the unit?
The timer and the motor run off of 120 volts but the heating coil requires the full 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
