I have a kitchenaid dishwasher that does not have any power. I checked the breaker and it is good. The outlet in which the dishwasher is ran from is good. I checked the thermal fuse by itself and has continuity. I then bypassed the fuse to check for power going to the fuse and control board and there is still no power being detected... Where do I go from here?????
I also bypassed the door latch also and still no power
Here are your parts Parts for Whirlpool KUDK03CTBL0 Dishwasher - AppliancePartsPros.comSee the attachment for the tech sheet. If you have 120 volts between P2 and P6 on the board and no signs of life, odds are that the board is bad. If there is no voltage there then you will have to check the power with a meter. Note that it is not uncommon for there to be problems at the wire nuts if the unit is hard wired in. |
THIS FORUM IS DEAD!!!!!!! |
