pep33
#1 Posted : Monday, October 12, 2009 9:07:33 AM(UTC)
pep33
I do not get any spark for the burners to lite but the oven still works. Is it possible for the spark module to be bad even if the oven ignites?
#2 Posted : Monday, October 12, 2009 11:44:33 AM(UTC)
There are two different types of ignition used in this range. The oven used a flat hot surface igniter while there is a spark ignition for the surface burners.
Most likely the problem with you range is a bad spark module.
- The spark module Part number: AP2126192
Bosch dual fuel range burners all spark but 2 burners don't ignite (Oven Repair (including Ranges and Cooktops))
by elizabeths 2/24/2021 8:16:50 AM(UTC)
Kitchen Aid gas stovetop burners don't ignite (Oven Repair (including Ranges and Cooktops))
by RhubarbRon 4/14/2011 2:25:54 PM(UTC)
Whirlpool SF385PEEZ Burners Don't Ignite (Oven Repair (including Ranges and Cooktops))
by njmacuser 2/20/2010 7:55:40 AM(UTC)
