Whirlpool Above range microwave has no signs of life. No lights come on. No buttons work. And display does not light up! So, the first things I checked where the inline fuse, and the Thermal fuses. Inline fuse has continuity. Thermal fuse on the magnitron also has continuity. Lastly I checked a thermal fuse that is directly behind the touchpad facing down to the oven. It is located right next to the door switches. My multimeter shows it to be open.
So, I disconnected the thermal fuse that was open, and jumped the wires as a test. This did not bring life back to the unit. What else may I check?
Read more: http://forum.appliancepartspros...-life.html#ixzz2jAguO4R2 http://forum.appliancepartspros.com
