crodenburg
#1 Posted : 11 years ago
crodenburg
when I turn on my machine to fill up for washing the water just runs out of the drain hose instead of filling up. I already checking for siphon. it wasn't the issue. What could this be?
HumboldtRepairMan
#2 Posted : 11 years ago
HumboldtRepairMan
is the drain hose running lower then the tub if so it'll do this..........is it leaking or just coming out the hose? Is the drain pump humming and making the water come out? Give a more detailed problem
