newmexico
#1 Posted: : Monday, October 28, 2013 9:45:29 AM(UTC)
newmexico
Can anyone tell me a part number for the tubing that runs between the single inlet water valve to the inlet side of the water filter housing. I have looked on all the parts diagrams and called Benton Harbor w/p parts and they were unable to help. It is approximately 80" in length. It appears to be a type of pex tubing with the ends moulded on. It has a quick disconnect (straight) on end that connects to inlet valve and an elbow with quick disconnect on end that connects to water filter housing.
Any help is appreciated. Thanks
